Power-up of bicycle
beatsal
Joined Jan 21, 2018
425
Looking to add a small motor to my bike for limited operation i.e. I pedal nearly all the time but at times come across an incline which I can't climb so need power assist for this i.e. 10 secs max each time. Thinking of using electric motor but not ruling out a small micro diesel, whichever best solves the problem. Any ideas appreciated.
schmitt trigger
Joined Jul 12, 2010
2,252
There are electric upgrade kits which usually involve replacing one of the wheels. It is the least expensive option and you can continue to use the bike you already own.
28,398
I suggest multi-ratio gearing as in the multi-speed bikes that have been around many years. Not the hub with internal gears but the vastly more durable and wider range of multiple sprockets. I can pedal up any hill that I can walk up in a normal posture. And the battery never runs down. I usually avoid inclines over 30 degrees, though.
beatsal
Joined Jan 21, 2018
425
Thanks! What MOTOR/battery size and V do you use?
28,398
No motor, just leg power. A motor on a bike is a problem getting ready to fail. And tempting to thieves and those who tamper with bikes. There are a few in my area.
Ya’akov
Joined Jan 27, 2019
10,308
Modern, 8 speed internally geared hubs are excellent and have plenty of ratio span. There is also the possibility of something like the DaVinci CVT which is continuously variable and (like the IGH) can be shifted without pedaling—very useful for practical urban transportation.
