Power transfer through stacked PCBs? Ideas?
Juhahoo
Joined Jun 3, 2019
302
Any ideas how should I transfer power through several stacked PCBs so that they are NOT using any screws or threaded parts so they would be just plug-in type connectors soldered to PCB in reflow oven?
Current range is around 20Amps +15Volts, space between boards around 15mm.
Something like this would be a perfect solution. One single connector contains male and female portion
AnalogKid
Joined Aug 1, 2013
12,256
That is the basis behind the original PC-104 connector system. It used 0.025" square posts, so it was good for about 2 A per pin. Board spacing was 0.6 ". One version was made with hi-temperature plastic, and had little solder donuts around each pin that flowed in the oven. Others were press-fit.
ak
Juhahoo
Joined Jun 3, 2019
302
ak
I thought of that first but, it just isnt really a high amp power connector, but...nowadays PC104 system can pass 5Amps per pin, so using 10 pins, 50Amps can be reached. It can also pass some signals/control making it versatile.
One option is to use double sided SMD stackers, but I have to use vias in between :(
Since single pin PCB through stackers aren't existing, the best idea so far is the above mentioned PC104 with through stacking option from Samtec.
35,101
20A is very high. What are you powering?
You cannot do this with regular pin headers. You need to reconsider this approach.
MaxHeadRoom
Joined Jul 18, 2013
30,791
If this is just a power pair etc, You maybe could look at the RC XT60 connectors, M & F, they are just a tad more in height.
60A rated. Digikey PRT-10474 for the M,F pair, solder to a PCB copper plane.
Juhahoo
Joined Jun 3, 2019
302
I have used previously in high current applications RC connectors between two boards, but none of the RC solutions cant be used between multiple stacked boards very easily, for prototypes its fine.
I'm considering some sort of custom bushbar system instead of stacked connectors like so..
It could be used in the middle of the board if there is a slot where the bushbar can be routed. This would be more protected rather than on the edge of the board.
