Power switch debouncing
Matt74
Joined Jun 29, 2019
30
I was, naively, wondering wether I should worry about power switch bounce. I am designing a battery-powered circuit for an nRF52 bluetooth module and I need a switch between the battery and the voltage regulator. Then I started to worry about the current spikes created when the device is switched ON/OFF and how it may affect the microprocessor. I read a few forum threads and articles including those below but they mainly deal with logic switches and not power switches:
https://www.allaboutcircuits.com/technical-articles/switch-bounce-how-to-deal-with-it/
https://my.eng.utah.edu/~cs5780/debouncing.pdf
Should I put a simple RC across the power switch ? How can I calculate the values of theses components ?
Thanks !
AlbertHall
Joined Jun 4, 2014
12,640
I doubt it's worth it. For high voltage switches or relay contacts a suppressor (a capacitor in series with a resistor) can be connected across the contacts to reduce arcing but for your application there isn't going to be any significant arcing.
Matt74
Joined Jun 29, 2019
30
Thanks, I am more worried about the microcontroller than damaging the switch. Arcing, you are right, is not an issue.
