Power Supply, running on 415VAC 3 phase
nglmrk
Joined Aug 27, 2021
Hello. I have a few components running on 415VAC 3 phase. But my incoming power is only 230VAC 1 phase. Is there anything that i can do to correctly and safely power up all my components?
dendad
Joined Feb 20, 2016
4,641
More details please!!!!
But if it is a 3 phase motor, you can buy variable frequency drives that run on 240V single phase and generate the 415V 3 phase.
A lot depends on the device in question and the power required.
nglmrk
Joined Aug 27, 2021
these are the components that im dealing with. with an incoming power of 230VAC
1) Electo Coagulation Equipment - 380VAC/3 Phase/50-60Hz/15kW
2) Feed Pump - 415VAC/3 Phase/11kW/22.8A
3) Backwash Pump - 415VAC/3 Phase/11kW/22A
LesJones
Joined Jan 8, 2017
4,543
I suggest for such a large power requirement (37KW) that you get your electricity supply company to install a three phase supply.
Les.
dendad
Joined Feb 20, 2016
4,641
Yes, indeed!
A single phase supply will not be enough.It is a pretty big load for any supply. It would need to be an industrial one, not a domestic version.
Sounds like big $$$ to me.
