Power supply pi filter
Wendy
Joined Mar 24, 2008
23,869
I had an old 15 volt power supply to my computer speakers getting pretty crispy. So I bought a new one. Unfortunately it is a switcher and very noisy to these old speakers.I was thinking about installing a filter along these lines.
Power supply pi filter.png​
I remember reading on these kinds of chokes that polarity matters. Before I build it I was just wanting to get a second opinion.
Parts Capacitor, Choke coil.
ronsimpson
Joined Oct 7, 2019
4,907
How much current does the amplifier draw? The filter chokes need to handle that much current.
Do you have large caps that you are not using. You could try just adding more caps and see what happens. It will not be as good but might work.
ronsimpson
Joined Oct 7, 2019
4,907
The choke/transformer is rated at 1A.
The inductance is listed at 40mH in one place and 40uH in another.
I tried to find the part somewhere different so I can get more information but cannot find it easy.
panic mode
Joined Oct 10, 2011
5,488
what is the switcher PSU that you plan on using? all supplies have limit for how much capacitive load they can handle. 20000uF sounds extremely excessive.
old rule of thumb is to use up to 2000uF per amp when filtering rectified mains frequency. switchers operate at much higher frequency (80kHz - 1Mhz). so filtering any remaining ripple should be fine with few smaller caps (meant to handle the frequencies you are trying to filter out).
Pyrex
Joined Feb 16, 2022
579
Of course, you can use such a filter. But the capacitance is way too high, about 1000uF would be enough. And you should connect ceramic capacitors, around 0.1uF to each of the two electrolytics.
Whether such a filter will be useful, nobody can say for sure.
It could be that the adapter itself isn’t well designed and it might need to be modified. First, you should make sure if the adapter has a mains filter like the one in this post. Secondly, are the HF rectifier diodes shunted with small capacitors (100-1000pF). Third, is there a small capacity (500-2000pF, Y-class) capacitor between the primary and secondary windings of the transformer. But you can only see that by taking the adapter apart, and that's not always that easy
schmitt trigger
Joined Jul 12, 2010
2,298
I measured it at forty-four mH each.
But….measured without DC bias.
Remember, for all inductors specified to carry significant amounts of DC current, the effective inductance must be stated at its rated DC current because inductance decreases, sometimes completely collapses, with DC bias.
schmitt trigger
Joined Jul 12, 2010
2,298
Under load the two currents are biased against each other. The core should not see any DC bias.
And by the same token, as already mentioned by Crutschow, the normal mode inductance will be quite small. Essentially leakage inductance.
THE bottom line; Wendy may use those common mode chokes to attenuate common mode noise. But to attenuate the normal mode noise (aka ripple) Wendy should also use another regular inductor rated for the expected DC load current.
Ian0
Joined Aug 7, 2020
13,317
It's got no net DC current because the magnetic fields from the two DC currents in the two windings cancel out.
ZhangSheng
Joined Sep 25, 2026
28
On the surge point, I would test it in stages rather than switching both 10000 uF caps in at once. Power it first with only the first cap fitted, then add the second, and watch the switcher output and the choke for any voltage sag or heating. Also check the choke is not saturating at your 1 A load — if its inductance collapses under DC current it will stop filtering just when you need it. Finally, measure the noise at the amplifier input with a scope before and after, with the input leads shorted, so you can tell whether what is left is common-mode or differential-mode ripple.
38,952
So, obviously that's why common-mode chokes can have a high common-mode inductance with a small core, since there is no worry about core saturation due to the supply current that flows in and out of the choke.
