I started this and was wanting to change output the transformer is 120 volts the output is 32 volts.
16 volts to ground plus and minus.
I'd like to modified the output to go plus and minus 15 volts but that would be like 5 volt up to 15.
I can live with that but I would like to go lower right now i only have lm7805 and lm7905.
I seen a lm317 doing both sides is there a way to do that and then go lower then 5 volts.
