GopikaMukundan
Joined Sep 5, 2024
5
Dear All,
I am a student with no background in electronics. I want to make a circuit with a DC power supply that supplies min ± 2kV to max ± 7kV to the circuit. I have a bipolar DC source with a mechanical switch to change the polarity. However, I am looking forward to setting the polarity change from negative to positive (and vise versa) with the frequency set on the function generator (~1Hz), It should work automatically with the set frequency. I have no idea how to set the circuit with the power supply for the set frequency. I have seen about the H bridge.
Can you please let me know how this can be connected and how can I use the DC power supply that supplies voltage in the range of ± 2kV to max ± 7kV with 1hz using the H bridge or corresponding equipment?
Looking forward to hearing from you
Sincerely,
Gopika
GopikaMukundan
Joined Sep 5, 2024
5
Thank you for your reply,
Yes, I am currently doing experiments with the same range. As of now, I am changing the polarity manually. But I want to leave it untouched and also need highly precise data.
28,600
I would caution all present that such high DC voltages can very quickly be fatal, both to the TS and for those with no understanding of the hazards. So I suggest that this is an area where those able to handle the voltages safely will already know how to create such a supply.
