Power Supply Leakage Checking
Yin Min
Joined Jun 24, 2019
29
Hi everyone,
I want to know how to check power supply leakage.Because my application is AC load. In normal condition, there is no DC voltage and DC current at load side. Now, I am getting a few DC current at load side. So, I am suspicious with the power supply. I am using meanwell power supply made in china. And I think some leakage in power supply.
Any other suggestions from you, please!
Yin Min
LesJones
Joined Jan 8, 2017
4,544
I don't understand your question. Both the power supplies are 48 volts DC output yet you say that you want them to supply an AC load. can you give more details of the nature of the load that you wish to power from these power supplies.
Les.
Yin Min
Joined Jun 24, 2019
29
Les.
Hi Les,
The following is my block diagram of system. In normal condition, there should not be DC current at load side. Now, I am getting DC current and AC current at load side. After I changed another power supply ( I mean different model and different rating of Meanwell power supply), there is no more DC current. So, I concluded that it is power supply fault. Now, I want to remove this DC current without changing another power supply.
Is there any solution to remove this unwanted DC current, please?? Now, I am trying to add on another filter circuit at the power supply output side. is this the right way to solve this problem?
Fig.1. Normal Condition
Fig.2. Faulty Condition
Thanks,
Yin Min
LesJones
Joined Jan 8, 2017
4,544
Your original description was confusing as the term leakage normally refers leakage from the input supply and the case of the power supply or it's output (If the output is floating.) (As described by DickCappels in post #5) You also did not mention the MOSFET driving circuit between the power supply output and the load. I think you need to give FULL details of the MOSFET driving circuit (Including the schematic.) so we can try to understand what is happening.
Les.
Yin Min
Joined Jun 24, 2019
29
Your original description was confusing as the term leakage normally refers leakage from the input supply and the case of the power supply or it's output (If the output is floating. (As described by DickCappels in post #5 You also did not mention the MOSFET driving circuit between the power supply output and the load. I think you need to give FULL details of the MOSFET driving circuit (Including the schematic.) so we can try to understand what is happening.
Les.
Okay.
