Power Supply Inspection.
Nomi 1114
Joined Dec 4, 2017
124
Dear All,
Hope everyone is fine. Here, I am interested to discuss one query that i have designed power supply for RF transmitter's PCB, Voltage range (5Vdc , 48Vdc). I have designed in Altium designer but unable to simulate (because Spice model of ICs are not available) this supply (220Vac to 5Vdc & 48Vdc), to verify weather it works well or not ? Kindly someone review this circuit and obliged me, and suggest me with their comments if there is any problem in circuit.
Anxiously waiting for prompt reply.
Regards
35,193
There are plenty of things that need attention.
1) All input components Ri1-Ri4 serve no purpose but to generate heat and waste power. Ri3 and Ri4 are too high. There will be little power input.
2) Dz1 will blow.
3) Why cascaded switching supplies? Why not just use one?
Nomi 1114
Joined Dec 4, 2017
124
2) Dz1 will blow.
Thanks for your kind attention and reply ... please suggest me better design , if you can .. I shall be highly grateful to you for this act of kindness.. Dz1 is zener diode for 12 V regulation..
Nomi 1114
Joined Dec 4, 2017
124
[/QUOTE]
Actually the first one is used for 12 V to 24 V and tye second one is used for 24V to 48V .. I didn’t found any specification directly 12V to 48V ...
ronsimpson
Joined Oct 7, 2019
4,822
How much current at 5V and how much at 48V?
What transformer? T1 What is its output voltage.
The voltage from the transformer needs to be in the 7-40V range to make the LM2596 output 5V at under 3A.
One single LM2586 can work with input voltages of 4 to 40V.
A 24V transformer will give you 30V (about).
Nomi 1114
Joined Dec 4, 2017
124
Dear respected ronsimpson,
Thanks for your kind cooperation, here i wanna inform you that current should be less than 3A is fine ... and i am bit confused that 220 V to 24 V transformer is available, if is it then it wil be good and suggested diagram is very good.. the last point the values used for capacitors and resistors are fine or needs to change ?? Please suggest me !!
Regards
ronsimpson
Joined Oct 7, 2019
4,822
UR1 Output 5V 3A input 30V 0.5A (If no loss)
UR3 output 48V 1A input 30V 1.6A
From transformer 30V 2.1A. 63 watts
We need a 220v to 24V 3 to 4A transformer.
100V 5A diodes.
Nomi 1114
Joined Dec 4, 2017
124
As per your recommendations i have designed the Power supply ckt for 5Vdc and 48Vdc. Here, i wanna ask one question, if i am interested to add one more point for 6.5Vdc. so how can i obtain the 6.5Vdc aslo form the under mentioned ckt as third output point. I found MP8606 IC can provide 6.5Vdc but current is too high i.e 6A. any other way ??
