power supply help
Bryan47
Joined Dec 1, 2010
6
Hey guys,
Desigining a small power supply, variable with an lm 317t. I haven't done this since high school
so I was hoping someone could just look over the circuit for me? It seems to work I just
want to make sure I didn't miss anything or if there are any improvements I can make.
Thanks!
PS its in a multisim file I'm not sure how to post it!
bertus
Joined Apr 5, 2008
22,999
In the FAQ there is given how to post attachments:
Attachments and Images
How do I attach a file to a post?
To attach a file to your post, you need to be using the main 'New Post' or 'New Thread' page and not 'Quick Reply'. To use the main 'New Post' page, click the 'Post Reply' button in the relevant thread.
On this page, below the message box, you will find a button labelled 'Manage Attachments'. Clicking this button will open a new window for uploading attachments. You can upload an attachment either from your computer or from another URL by using the appropriate box on this page. Alternatively you can click the Attachment Icon to open this page.
To upload a file from your computer, click the 'Browse' button and locate the file. To upload a file from another URL, enter the full URL for the file in the second box on this page. Once you have completed one of the boxes, click 'Upload'.
Once the upload is completed the file name will appear below the input boxes in this window. You can then close the window to return to the new post screen.
What files types can I use? How large can attachments be?
In the attachment window you will find a list of the allowed file types and their maximum sizes. Files that are larger than these sizes will be rejected. There may also be an overall quota limit to the number of attachments you can post to the board.
How do I add an image to a post?
If you have uploaded an image as an attachment, you can click the arrow next to the 'Attachment Icon' and select it from the list. This will be inserted into your post and can be located where you want it displayed.
To include an image that is not uploaded as an attachment and is located on another website, you can do so by copying the full URL to the image, (not the page on which the image is located), and either pressing the 'Insert Image' icon or by typing
after it, ensuring that you do not have any spaces before or after the URL of the image. You can insert pictures from your albums (?) in this way too.
You can also post a screenshot of the circuit as not all have multisim.
Bryan47
Joined Dec 1, 2010
6
Sorry I'm on a mac using bootcamp and couldn't get the Screen Shot to work. Here it is! Thanks!
Transformer is 24 V on the outside 12 V center tap
Audioguru
Joined Dec 20, 2007
11,248
24VAC produces a rectified and filtered +32.5V. Extra input voltage causes a lot of heat in the regulator. The LED will have a current of about 30mA and might burn out unless it is a big one.
A more expensive LM117 uses a 240 ohm resistor for R2 and an LM317 uses 120 ohms so that the voltage does not rise without a load on some LM317s. Then the value of the pot must also be reduced.
The LM317 reduces its max output current when its input to output voltage is higher than 15V. If the input to output voltage is 40V then the max current might be reduced to only 150mA.
Your circuit shows a pot that adjusts the output voltage down to 1.25V. If much current is drawn from the output at a low voltage then the IC will get extremely hot and will shut-down.
gootee
Joined Apr 24, 2007
447
You can usually lower the output ripple significantly if you put 10 to 22 uF from the LM317's Common pin to ground. But you might then want to also install the standard protection diodes (1N4002 from ADJ (Common) to VOUT and 1N4002 from VOUT to VIN, although you wouldn't really need the one from vout to vin unless the output capacitor was larger).
The LM117 datasheet from national.com is highly recommended.
