Power Supply Help Please ?
HaseebEngineer
Joined Aug 8, 2013
22
I have made this power supply to have an output of 30v , 4ampere .. I have also implemented this on a breadboard...my Digital Multimeter is giving an output from 3v to 30v with this regulated power supply ... But the current is not 4ampere ... its about in miliamps ... WHY ????? Why ???
My transformer output is 24v RMS and 8Ampere ... The rectifier i used are 4x1N4007 ...
18,146
Maybe because there is no load except air? How much current were you expecting to drive through the air?
Dang, #12 beat me again.
tubeguy
Joined Nov 3, 2012
1,157
1n4007 diodes are rated at only 1 amp. You need proper diodes. Best to use a ready-made bridge rectifier at least 8 amps.
It's not safe to hook a 30 volt zener directly across a 30 volt max supply. (everything has tolerances)
PackratKing
Joined Jul 13, 2008
847
Levity aside, tubeguy is right about the inadequate diodes.
Shouldn't OP have a load resistor immediately downstream from the filter cap @ C1 after the rectifier ? Re: the thumbnail... or does the load res. belong at the output end...
Also Tantalum caps on the input / adjust for the U1, and a cap on the output ??
There are so dang many ways to skin this cat, is why I ask...:rolleyes:
He should also have C2 on the other side of the 500 ohm resistor, but it seems futile to clean up the details when the OP doesn't even know what current is.
18,146
Even with R3 removed, which is critical, the current at 30V will be limited since this is well above the 24V rms rating of the transformer, for which we don't know the current rating.
ian field
Joined Oct 27, 2012
6,536
Its better to use single rectifiers rated for the job, than putting 4 in parallel to make up the rating - manufacturing tolerance means one diode will conduct more than the others and fail S/C! You also need a safety margin - a bridge rectifier rated at least 6A.
If you mean the 4x 1N4007 are the bridge rectifier - you'll be letting the magic smoke out pretty soon.
I do hope there's a fuse protecting the secondary of the transformer!!!
ScottWang
Joined Aug 23, 2012
7,505
Take R3 away and shorted two pins.
Take D3 away.
Bridge rectifier - 100V/6A(>=60V) or rectifier diode - 100V/6A. (>=60V)
D1,D2 → 100V/4A (>=60V)
C1 → 2200uf/50V
C2 → 470uf/50V or 220uf/50V
Vout in parallel with a 0.1uf/50V (Multilayer Ceramic Capacitors)
AC220V in series with a fuse. (0.87A fuse for 24V/8A output, could using an 1A fuse)
