power supply for 4066 analog bilateral switch
PeteHL
Joined Dec 17, 2014
596
It is recommended that power supply for the 4066 when used as an analog bilateral switch is +/- 5V. In my circuit that amplitude modulates a sine wave signal, the power supply for that circuit is +/- 8V. Will this degrade operation of the switch, and if so, in what way?
The circuit is my implementation of a cosine burst generator roughly following the design by Linkwitz. The power supply of what he designed is +/- 6V. If interested or if need be I might be willing to describe the circuit in greater detail.
Thanks in advance,
Pete
OBW0549
Joined Mar 2, 2015
3,565
Looking at the data sheet for a CD4066B, the Recommended Operating Conditions specify a total supply voltage (Vdd - Vss) of 3 to 18 volts:
So it would appear that ±8 volts should be OK.
As for degradation, I wouldn't expect any; in fact, with most analog switch ICs, the higher the supply voltage the lower the ON resistance of the switch-- that is, higher supply voltage improves performance, at least with respect to Ron.
eetech00
Joined Jun 8, 2013
4,733
Thanks in advance,
Pete
Hi
The bipolar supply is needed to pass a bipolar signal. According to the data sheet the max bipolar input signal is 7.5v pk-pk (or 3.75v pk). As long as the input signal does not exceed the recommended..should be ok.
eT
Audioguru
Joined Dec 20, 2007
11,248
Hi
No. The absolute max input is plus or minus 9V (18V p-p) but plus and minus 7.5V (15V peak-to-peak) is recommended as a max.
A bipolar supply is not needed if the input and output have coupling capacitors and the input is biased at half the supply voltage.
PeteHL
Joined Dec 17, 2014
596
hi,
A point to be aware of is the Control Voltage for the 4066 with reference to the supply voltage.
E
In the chart, is this assuming that pin 7 of the 4066 is at ground? In other words, the max. control voltage is with respect to supply voltages of 5V, 10V, and 15V?
Then for example where Vdd equals 5V, does the chart mean that the control voltage should not exceed 3.5V with respect to ground, or the voltage at pin 7?
PeteHL
Joined Dec 17, 2014
596
@OBW0549 and @dl324
I agree, but then I don't see why Linkwitz and Don Lancaster in his CMOS COOKBOOK specify respectively 12V and 10V supply voltages. In Lancaster's book, the 10V supply is Vdd= +5V and Vss = -5V when routing an analog signal referenced to ground through one of the switches .
Thank you,
Pete
Audioguru
Joined Dec 20, 2007
11,248
Pin 7 is logic and input ground. Pin 14 is the logic supply and analog maximum positive input voltage. The chart does not show the maximum allowed control voltage. Instead it is the minimum logic high control voltage. An ordinary CD4001 and CD4011 logic IC also has the same minimum logic high input voltage with respect to its supply voltage.
OBW0549
Joined Mar 2, 2015
3,565
No, that's the minimum voltage at the control pin needed to turn the switch on. The maximum voltage that should be applied to the control pin is the positive supply voltage.
@OBW0549 and @dl324
So long as the supply voltages are adequate for the analog signal range, and are within the Absolute Maximum Ratings of the part, the choice between 12V and 10V is entirely up to the designer's preference. The fact that one designer chose 12V and the other 10V, is of no significance.
PeteHL
Joined Dec 17, 2014
596
Yes, thanks, that agrees with what I currently understand about 4066. I was thrown off by the use of the term "high", meaning the control voltage that makes the switch low resistance.
