Power Supply board - burnt out resistors
sunomo
Joined Dec 23, 2018
12
Hi everyone, I'm trying to repair a Sony PVM 2730QM monitor. The picture flickers and shakes very much and I hear a strange electric noise.
The source of the noise is the Power Supply board. I dismantled the board and through an eye inspection, there is an external burn between the C621 C682 capacitor block and the R679 resistor. I think that the resistor burned first and those on the capacitor protection are just residual.
I can easily replace these components, but I need to understand the reason of the fault, otherwise it's going to happen again. I tested D609 diode and Q606 transistor off board with multimeter and they should be ok. Any suggestion to start testing or repairing?
All the schematics attached. Thanks in advance!
Full Service Manual: https://archive.org/download/sony_PVM-2730QM_Service_Manual/PVM-2730QM_Service_Manual.pdf
AlbertHall
Joined Jun 4, 2014
12,347
The black mark on the resistor doesn't look like it was caused by overheating - that generally shows worst in the middle and getting less towards the ends and evenly around the circumference. That resistor is blackest at one end and the blackness does not spread around the circumference. The insulating sleeve (which I guess was around the resistor) has a very localised black circular mark which again doesn't look like it was caused by the resistor overheating.
I think this was caused by arcing from the resistor through the sleeve to whatever was next to the sleeve. Part of the strange noise may have been the sound of that arcing. Was one of the capacitors next to that burnt mark on the sleeve? If not what was?
Measure the values of all the components connected to the collector of Q602 - four resistors, two capacitors and the diode.
oz93666
Joined Sep 7, 2010
739
The black mark on the resistor doesn't look like it was caused by overheating - that generally shows worst in the middle and getting less towards the ends and evenly around the circumference. .
That might be true for carbon resistors , but I think the one pictured is wire wound , in which case a hotspot could have developed leading to failure consistent with picture evidence .
Many KV would be required to produce arcing... Where could this come from?
The fault may have occurred because the two components were in contact , make sure there is space all around the resistor . Not sure of the reason for the fiber glass sleeve this will only cause overheating.
sunomo
Joined Dec 23, 2018
12
Thanks for your messages. Those 2 capacitors were inside that sleeve, not the burnt resistor. The black spot on the resistor was in front of the black dot of the sleeve. Maybe the noise was an arcing between these two blocks, but why? Also I suspect that it started from the resistor because the capacitor sleeve inside is completely white. I've tested off circuit the components near Q602, four resistors and the diode, and they are ok. I've replaced the 2 capacitors and the burnt resistor. Now should I plug in the electricity?
AlbertHall
Joined Jun 4, 2014
12,347
Yes, I think so. I can't think of anything else you could usefully do. Just ensure you have as much space between the components as possible.
There will be quite high voltage peaks there because of the back emf from the transformer. Those components are intended to absorb the energy from those peaks and so reduce the voltage. So faulty components could increase the voltage.
sunomo
Joined Dec 23, 2018
12
Hi, I've turned it on, I still hear that sound, but far less than before. Anyway now on the +15V live I have +13.5V and on the +140V line I have +135V. Unfortunately I have nothing on the +8V line and the monitor does not switch on. What else should I check?
sunomo
Joined Dec 23, 2018
12
C659, R677 and D656 are ok. On R677 I have just 0.2V but it's very hot. About C655 I don't have anything to test a 2200 capacitor. So I swapped it with the equivalent C654. The result is that now I don't have anything on both 8V and 15V lines. Tomorrow I buy 2 replacement capacitors, but is that the key or the fault is still somewhere around?
sunomo
Joined Dec 23, 2018
12
Thanks for you message. Ok, I've replaced those 2 capacitors, and now I've around 8V 15V 140V on the respective lines, the monitor degauss but the front panel and the tube don't switch on. Maybe it is due to the fact I've no voltage on FA8 line (the one in the lower right corner in the scheme)? What should I expect there? Btw I still hear a sound from the supply board, but now it's very similar to a cricket sound...
sunomo
Joined Dec 23, 2018
12
I've another PVM2730QM 100% working, so I've tried to put into this faulty one a working PSU. The monitor degauss and the tube turns on. However the control panel with its leds are still disabled and the screen is light blue. Since I also hear a constant hiss, I think that also the flyback needs to be replaced. Btw no cricket sound with this one. Anyway to start understanding what's wrong with the faulty PSU I could try to compare the out voltages between the twos, but what else?
sunomo
Joined Dec 23, 2018
12
Here is the voltage value comparison between the faulty PSU with a working PSU.
Woking PSU:
8V line 12.3V
15V line 15.7V
140V line 141.8V
+18V line 21.9V
-18V line -21.6V
Faulty PSU:
8V line 10.5V
15V line 15.6V
140V line 129.7V
+18V line 23.2V
-18V line -22.5V
Are these values acceptable? This deviation could be the reason why the tube does not switch on? If so what else should I check on the faulty PSU?
Thanks
sunomo
Joined Dec 23, 2018
12
I've put in the same non-working monitor a working PSU taken from another working twin monitor and then I've put back the original faulty one. I got these values for 2 different PSU into the same non-working monitor. The Working PSU is able at least to switch the tube one, the faulty original PSU is even unable to do that.
