Power supply 230VAC/24DC input, 24V, 12V, 5V, 3.3V output
starsnpixel
Joined Dec 23, 2018
10
Hi guys,
I have zero experience with power supply design so I hope you can help me with choosing the right one. The system I want to run has the following properties:
Input (either or, not simultaneously):
- 230VAC
- 24VDC
Required outputs (simultaneously):
- 24V @ 2,5A
- 24V @ 1A
- 12V @ 0,1A
- -12V @ 0.1A
- 12V @ 3.5A
- 12V @ 3.5A
- 5V @ 3A
- 5V @ 2.5A
- 3.3V @ 0.1A
- 2V @ 0.4A
My idea was 1. a converter from 230VAC to 24VDC and then stepping to the respective voltages from there. But maybe there's a better solution? I thought about an ATX computer power supply unit but one that runs with 24VDC input but the only one I found is ~$360. Any help is greatly appreciated!
Dodgydave
Joined Jun 22, 2012
11,395
If your inputting 24V dc, then you only need a Variable buck regulator, or a separate regulator for each voltage under 24V..
dl324
Joined Mar 30, 2015
18,523
I'd drop the AC input option and just accept 24VDC input. Is that 24V power source capable of sourcing 18-20 amps?
AnalogKid
Joined Aug 1, 2013
12,298
Critical question - when running on the 24 Vdc input, do the output have to be galvanically isolated from the input? If the application is vehicle or MIL power, the answer almost always is yes.
Also, does the supply have to meet safety certifications (UL, CSA, TUV, etc.)?
Also also, do the duplicated outputs need to come from separate regulators?
Also also also, is there any specific power-up or power-down sequencing required?
I've done this more than once. Typically I'd use a 24V/24V DC/DC converter with enough output current to run everything, then post-regulate all of the other outputs with linears or bucks. A 555 or a small buck/boost can generate the -12 V.
ak
BR-549
Joined Sep 22, 2013
4,928
It's a bad idea to start out with such a difficult project.
A desktop computer power supply will give you over half of the stated specs. 30 bucks brand name amazon. Cheaper on ebay.
Then add separate 24 V and 2 V supplies.
AnalogKid
Joined Aug 1, 2013
12,298
Sounds a bit high; more like 12 A. The total output power is around 200 W, or 8.33 A at 24 V. With 80% efficient main and post regulators, that's about 4.4 A for an isolated 24 V output. The other outputs are dual-converted and add up to about 7.5 A at 64% efficiency (80% in the 24 V DC/DC and 80% in the post regulators).
-ish
ak
dendad
Joined Feb 20, 2016
4,642
Probably some actual info on what the load for each supply is may help. Why do you need so many?
Would 1 x 24V, 1 x 12V, 1 x 5V, along with the -12V, 3.3V and 2V be ok?
Is there any reason you need the separate ones?
starsnpixel
Joined Dec 23, 2018
10
Thank you very much for all your replies, I'll try to answer them as good as I can:
Unfortunately I cannot simply drop it, the system is required to run with both options. The 24V source should be fine with the amps.
- I'm not sure about the isolation. The source is a 25 Ah battery if that has anything to do with it?
- It doesn't have to meet safety certifications. As long as it doesn't inflame spontaneously, it'll be fine. ;-)
- The list of outputs may be misleading, it's the loads that I listed here. So I guess the duplicated outputs could come from the same regulator.
- There's no sequencing required.
- Thanks for your design idea!
- Can't do nothing about the level of the project, I have to do it. ;-) I'm the guy with the most experience in electronics in the team.
I thought about an ATX supply as well and there are even some with 24V support but unfortunately the ones I found don't provide enough current @ 24V.
As mentioned above, I don't think seperate ones are necessary. The "output" list is misleading, it's a "loads" list (but I cannot edit it anymore).
AnalogKid
Joined Aug 1, 2013
12,298
If the 24 V input is coming from a battery, does it have to be regulated or stabilized or can it run the 24 V loads directly with an output that varies from 21 V to 28 V depending on charge?
What is your experience base with DC/DC converters like non-isolated buck converter modules?
For an AC/24 Vdc converter, are you considering a high-density "brick" or an industrial single-output switcher?
What are you initial thoughts on packaging, connectors, fans/heatsinks/cooling?
ak
dendad
Joined Feb 20, 2016
4,642
That is a very important question. If your application can run on raw 24V, as from a battery, then the supply just go easier. All that is needed is the 24V to lower voltage regulators and a battery charger.
starsnpixel
Joined Dec 23, 2018
10
In the manual of the 24V source, it says: "In all cases where input sensitive hardware is used, DC-DC converters are recommended." I think all our hardware is capable of tolerating fluctuations to a certain level, should be fine.
Due to my electronics background, I understand how they work but I don't have hands-on experience.
I was thinking about this guy here https://www.arrow.com/en/products/hrp-300-24/mean-well-enterprises A little oversized but those with less power are more expensive and only have none or a small current buffer.
Haven't spend many thoughts on that yet tbh.
What do you think about the 230V converter mentioned plus this one here? https://www.bicker.de/index.php/eng/content/view/full/1118 Runs with 24V and has all the outputs I need in one compact box and as far as I see it, has sufficient amps in every channel.
dl324
Joined Mar 30, 2015
18,523
Building a 200W supply that operates from AC or DC isn't a simple task. $360 seems like a good deal to me for an off-the-shelf solution.
AnalogKid
Joined Aug 1, 2013
12,298
I used Meanwell supplies (but not that exact one) a few times over the years and I like them.
Where are you located?
What is the final application (industrial, medical, military, outdoors, etc.)?
ak
