Power suply for kit stm32 blue pill
lehieubk98
Joined Mar 29, 2019
27
I'm working on a project using kit stm32 blue pill. I designed a power suply circuit, but the kit was damaged. Please tell me what was wrong in my circuit?
I used Adapter 15V 2A.
Dodgydave
Joined Jun 22, 2012
11,395
5W resistor is to limit the current, ideally it should be 10W, you don't have any 100uF electrolytic capacitors in your circuit on the outputs of the regulators...
djsfantasi
Joined Apr 11, 2010
9,237
It's just like I plug directly the phone charger (5V, 2A) into the kit without any resistor. Is that right?
Yeah, if you’re lucky. Any failure of downstream components will cause a chain reaction. So you design to protect that from happening.
The recommended circuit for the 7805 from the datasheet, calls for much larger capacitors. Without the, the regulator will fail, and well, NOT regulate.
lehieubk98
Joined Mar 29, 2019
27
I'll find it out, thanks for your suggestion.
lehieubk98
Joined Mar 29, 2019
27
I checked the datasheet and didn't see any resistor limiting the current between source and input of 7805. Do you think the 5W resistor here is necessary. Because I know that the input current depends on the output current.
Since we don't have pic, we also have to assume stuff. What is the output voltage?
We don;t know what package your using either. The tabs of a TO-220 generally are kept electrically insulated from each other with a to-tto mounting kit. Some kits need a silicone grease, others do not.
For the 7805 in a to-220 pkg, the tab is ground and for the LM1117 in a TO-220 pkg, the output is Vout. Connect them together bad things happen. Chassis with no mounting kit.
lehieubk98
Joined Mar 29, 2019
27
Sorry if there's something not clear. From this power suply circuit, I take 15V voltage for LM324 and a gate mosfet driver IC (IR2125); 3V3 voltage for kit STM32F103C8T6 (blue pill).
And also I use TO-220 for both LM7805 and LM1117. then what bad things happen when I connect them like that? Can you expain it to me? I'm newbie, so sorry if my question is awkward. Because I can't research these things on Google.
ScottWang
Joined Aug 23, 2012
7,509
R3 was used for reducing the input voltage, normally the 7805 can be input from 8~12V, when the power input is 15V then you can count it as input 8V and the other 7V (15V-8V) using the R3 to take over the power dissispation, if the max output current is 500mA then W = V*I = 7V*0.5A = 3.5W, use it at least 3 times of calculation values in the real world, if the draw current almost less 300mA then 10W is enough, if the draw current always close to the max current then you will need to use 15W.
lehieubk98
Joined Mar 29, 2019
27
Thank you all. Now I know how it works.
For more protection of the kit stm32, I intend to add a resettable fuse (500mA) before 3V3 pin of the kit.
Do you think that's useful?
If you make R3 a metal oxide resistor, it will help with overloads. They tend to vaporize and act as fuses,
A diode would help.
If you can afford the voltage drop of a full wave bridge, that would make the adapter not care.
Watch out for unregulated adapters. A transorb might help. They come in directional and bi-directional.
lehieubk98
Joined Mar 29, 2019
27
A diode would help.
I use a ceramic resistor for R3. Is adding a fuse better?
DickCappels
Joined Aug 21, 2008
10,661
A fuse would not hurt, but the regulators already have over-current protection.
R3 is there to lower the temperature of the 7805 by reducing the voltage on its input. That's a different function compared to a fuse.
