Power Push Switch and Voltage Drop?
DJ_AA
Joined Aug 6, 2021
502
Hi
Is it normal that a push switch on a PCB can cause a voltage drop on a battery?
I would like to place a switch between a battery and a circuit.
ericgibbs
Joined Jan 29, 2010
21,573
hi DJ,
A switch with contacts rated to carry the current required by the circuit may create a very small drop in the supply to the circuit.
E
28,322
Hi
Connecting an current consuming load to a battery will cause some voltage drop, which may be measurable but not enough to matter. That is because switches and wires, all exhibit a bit of resistance. The one exception is some simulators, where connections have no resistance.
DJ_AA
Joined Aug 6, 2021
502
Previously I had a switch and wire between the battery and PCB. So I guess that was as adding additional voltage drop.
dl324
Joined Mar 30, 2015
18,471
It would be helpful if you provided more information. Switch type, current involved, and voltage drop tolerance.
These switches have a contact resistance of less than 0.01 ohms (typical).
28,322
Mostly the voltage drop of one of those switches operated within it's ratings is so small that it takes a sensitive meter to measure it. That is to say that the voltage drop may be about 0.003 volts, (3 millivolts). The result is that it does not matter for normal applications. If the switch has been damaged or used far beyond it's ratings the drop may be a bit more.
