To do it you need to use another 555 connected as a bistable. The third 555 will trigger the bistable 555, the bistable output will go high. The output of the bistable will be connected to the reset pin of the last 555 and it will charge C11 (disconnect C11 from the positive power supply and connect it to the output of the bistable). Also, disconnect the THRS pin of the last 555 from the circuit.
