Power Measurement of SRAM using LTSPICE
Ssdiya
Joined Dec 30, 2020
Hi
I am doing the simulation of SRAM using LTSPICE. I need to calculate the leakage power of the SRAM. How to calculate the power in LTSPICE??
Bordodynov
Joined May 20, 2015
3,431
I changed the connection of the substrate pin. I also used other models with sub-threshold current parameters. In other words I added leakage transistors.
All information is on the wiring circuit diagram.
Bordodynov
Joined May 20, 2015
3,431
One, I am not a teacher.
You can try to calculate the maximum maximum frequency of the memory cell. Cell current at different frequencies of operation.
It is important to use the correct transistor models as well as the parasitic parameters such as drain and source areas and perimeters.
