Power management solution to generate +-12V from 3.3V
nadirEatsKoukies
Joined Dec 11, 2020
17
Hi all,
As the title suggests, I've been looking for power management ICs (preferably Texas or Linear Tech) that can generate two outputs (12V and -12V) from a single 3.3V supply. I haven't found any IC that does the trick so I'm asking if anybody here knows of any?
Thanks,
DickCappels
Joined Aug 21, 2008
10,662
On Semiconductor makes a version of the MC34063 that operates down to 3.0 volts -maybe lower if you are allowed to depend upon luck. Add a secondary to their example circuit for a boost converter and you have a winding for your -12V supply.
Papabravo
Joined Feb 24, 2006
22,114
