I'm using a wire foam cutter where the bridge wire heats up on a low DC voltage but it is not getting hot enough. The unit is 240v converted to 5v in a plug in transformer which simply runs up to the cutting wire. the wire was 0.23mm gauge and I've tried 0.21mm, expecting the resistance to be more, thus creating more heat, but there seems to be no change. looking for a cheap solution as once done with it will be binned.
* Should maybe add the power output is 2a and the wire cutter is 8.7w.
