I have a relatively recent HP laptop, the battery (internally fitted) swelled up and died a couple of years ago so I removed it and have been running the laptop off AC mains, via its dedicated charger/power supply ever since.
We are, however, subject to frequent power blackouts so I want to power the laptop from a LifePO4 battery pack with a regulated 19 volt output. The official replacement battery is a fearsome price and I'd prefer an alternative.
These HP laptops use a jack connector with 3 conductors: +19V, ground, and a central 'sense' pin. If I use only the 19V and ground then the laptop does not power up. I have seen a solution?? whereby the 'sense' pin connected to the 19V with a resistor, which then provides the voltage/current that the laptop requires to start up.
Anyone here familiar with type of setup who is willing to help me get this going?
