Power Factor - Apparent Power Calculations
ooxneozoo
Joined Jul 20, 2017
7
I'm in the AC text book on chapter 11 under power factor. The question I have is regarding the image/link below.
If S=Apparent Power= I²(Z), then how does that = 169.256?
Wouldn't Z = XL + R
Z = 60.319 + 60
Z = 120.319
Then S = I²(Z)
S = 1.410²(120.319)
S = 1.9881(120.319)
S = 239.206 ?
*I'm not getting 169.256 as shown in the textbook and image below. Even when applying pythagorean theory I'm unable to come up with the answer given.
Can you please tell me where I am going wrong on this?
https://www.allaboutcircuits.com/te...ent/chpt-11/true-reactive-and-apparent-power/
True power, reactive power, and apparent power for a resistive/reactive load.
LesJones
Joined Jan 8, 2017
4,539
You have only added the resistance to the reactance. They are considdered as being at right angles to each other so you have to use vector addition. so Z= √60^2 + 60.319^2 =√3600 + 3638.38 = √7638.38 = 85.08
Les.
ooxneozoo
Joined Jul 20, 2017
7
Les.
Thanks, i did forget to add the angles. Though, when I do, I still only get the 85.08 that you show. I don't get the 169.256VA, can you show me where I'm going wrong?
z = 60.319 < 90 | 0 + j60.319
+ z = 60 < 0 | 60 + j0
_______________________
z = 85.08 < 45.15 | 60 + j60.319
ooxneozoo
Joined Jul 20, 2017
7
NVM, forgot to add the original formula! Need more coffee :D
1.410^2(85.08) = 169.147
