Power Dissipation Issues
stdio.h
Joined Feb 18, 2015
3
Hey!
I built a circuit with a 5V power supply and a 300 ohms resistor. With a multimeter I did the measurements of resistance, voltage and current across the resistor. The values was:
R = 298 ohms
E = 4.94 V
I = 16 mA
So I made the calcs to obtain the power dissipated by the resistor:
P = EI = 4.94 * .016 = 79 mW
P = E²/R = 4.94² / 298 = 81.9 mW
P = I²*R = .016² * 298 = 76.3 mW
My question is: Why there are differences between the power results? It's because of the lack of precision in measurements, the increase of resistor's resistance when powered or a combination of both?
bertus
Joined Apr 5, 2008
23,031
The precision of the current is to low.
The current will be 4.94 Volts / 298 Ohms = 16.5771 mA.
When you do the calculations with this value the power will be 81.89 mWatt.
#12
Precision problems. I calculate 16.577 ma, but most meters don't go that far down in the digits. Neither do they measure closer than a tenth of an ohm.
#12
You can spend big bucks for something that has 5 or 6 digits, but it usually doesn't matter unless you're servicing precision analog meters.
Most people (including me) get along with a $10 POS except for rare occasions.
stdio.h
Joined Feb 18, 2015
3
High precision multimeters do not have a hobby price:
http://www.newark.com/keithley/2000...2/dp/58T8718?MER=PPSO_N_P_EverywhereElse_None
We will have to do with that what is in our budget.
Yes! I know. I was just justifying the lack of precision in my measurements. The HM-1000 is good enough for me.
18,184
Did you actually measure the 16mA current, meaning your meter was part of the circuit? That would introduce some series resistance and lower the current. If you have a second meter, you could measure the ∆V with the first meter in place.
