Overview - I would like to install an Apple AirTag in a vehicle and have it gets its primary power from the vehicle's 12V battery. In the event that the 12V Battery is disconnected, I would like for a backup 3V Battery to continue to provide the power required to run the AirTag.
Approach - Here is what I think I need for this circuit solution to achieve
Current Diagram - Here is my current diagram for your review. Looking for your suggestions.
Thank you in advance for your review.
Mike
- The Apple AirTag runs on 3V and about 230mA.
- I would like to hide this unit where it is hard to get to, the coin battery typically lasts 1 year. I would like to power off the 12V
- I will be removing the AirTag speaker to help make it's location obscure.
- I would like the Vehicle Battery to be the primary power source of the Apple AirTag.
- Use of a Buck Converter to bring the Auto Battery 12V down to 3V (actually 3.7V for Diode voltage loss)
- I would like ton include a 3V Battery for backup in case the Vehicle Battery is disconnected.
- Place a 3V LIR2032 Coin Battery in parallel to the Buck Converter power supply
- Wanting the 3V Battery to sit idle and not provide any power until needed.
- If it is not used, there should be no need to trickle charge it.
- Trying to avoid placing another Diode in the 3V Battery circuit due to slight voltage drop.
- The LIR2032 is a Re-chargeable version of the CR2032, as I believe the current diagram may attempt to charge this battery.
- Place a Diode between the 3V Battery and Buck Converter for converter protection.
- The AirTag does require 3V to 2 separate terminals and Ground to 1 terminal.
Mike
