power amp protection circuit simulation
ntetlow
Joined Jul 12, 2019
71
I've bought the pieces to assemble the power amp K8060 Vellman amp.
Before I do I've put together the LTSPICE schematic to test the circuit and to understand the electronics involved. I would like to simulate the sittuation where the precaution part kicks in and the Darlington pairs are cut off. Can anyone tell me how I can simulate this either by changing the input or altering resistance values somehow? Ive attached thhe asc file I'm using.
wayneh
Joined Sep 9, 2010
18,184
If the protection is meant to protect against a short, I suppose you could short the output, or maybe use a 0.1Ω resistor as the load. That would let you see the current and power there.
