Potentiometer taper too loud for low volume
ghulse
Joined Oct 19, 2023
8
I've made a miniature stereo using a bluetooth/MP3/SD card player and an Adafruit Class D 20 watt stereo amp, powered by a 12 volt DC plug that is split between these two devices. It's controlled by a volume knob (10K Ohm Single Linear Taper Dimmer Potentiometer with on/Off Switch) to turn the device on-off and control volume. The device turns on at about 9 oclock but jumps to a fairly high volume before I even get to 12 oclock position. No low volume to speak of. I chose a 10K Ohm pot for no particular reason. Might a 1k Ohm pot give me better low volume?
Alec_t
Joined Sep 17, 2013
15,158
Welcome to AAC!
For audio use you want a log taper, not linear. The logarithmic type 'stretches out' the volume change at the low volume end.
A 1k pot wouldn't improve things.
Audioguru again
Joined Oct 21, 2019
6,826
A volume control is supposed to have a Logarithmic taper and is marked "A" so that it matches the logarithmic sensitivity of our hearing.
When you turn down a linear pot to halfway, the loudness is turned down only a little, turn it down more and it is still too loud.
38,861
You can add a resistor from the output to ground, to give the pot a quasi-log output.
The LTspice sim below shows the output on a linear scale (yellow trace) and a log (dB) scale (green trace).
The log output would be essentially a straight line for a true log.
You can adjust the value of R2 to give the results you want.
ghulse
Joined Oct 19, 2023
8
Welcome to AAC!
Thanks for this info. I'm impressed with all of the responses to my question. Was expecting to be criticized for not providing a schematic. But so I ordered a log taper from Adafruit. Thanks again. Very helpful!
