The restive material may be burned out.If i have a potentiometer that all of the range of adjustment occurs briefly within the full range. What does that indicate? Thanks in advance.
I'm with #12.Either it's broken or it's an audio taper potentiometer.
Assuming nothing's broken, it could mean many things.If i have a potentiometer that all of the range of adjustment occurs briefly within the full range. What does that indicate? Thanks in advance.
All that verbiage is nonsensical and smacks of trolling.Ok sorry it took a minute to respond. I'm at work still pondering this. Hooked up last night thru lm317 power supply. Wanna say 13.6 v into the lm317. Oddly only getting 7.6v out with said pot. I added another lm317, 10v. Added a total of four in parallel. 12.4 v. Pot never did act right I have no more good ones. When I tested resistance. Seemed to spread across the normal range. With voltage - all changes within a small window.
No, junior, listen up. *We* know a lot of things about the LM317. Obviously you don't, or you wouldn't be asking us.WTF? You don't know how to wire an lm317 plz don't!
Obviously with little idea of what you are doing and arrogant. Bad combination.analog you ok man? i have 4 running in parallel. the question has been adequately answered. have a nice day.
by Jeff Child
by Jake Hertz
by Jake Hertz
