Yes, It is correct. But in real life, the positive and negative saturation voltage will not be the same.Is that now correct?
So, real-world measurement will show a different result.
I gave you the pictures to have a look? The real world figures/analysis.Do you have any more questions about the circuit?
yesIs this blue waveform a voltage at the opamp output? Because it looks more like it was a voltage at the non-inverting input.
Could you ease explain each step for me please. Like Equation 1 = and so onLook:
(5V - 2.5V)/12kΩ = (2.5V - Vin)/18kΩ
(2.5 - Vin)/18 = 2.5/12
(2.5 - Vin) = (2.5*18)/12
2.5 - Vin = 3.75
Vin = 2.5 - 3.75 = -1.25V
I thought it's not 1.25 and 2.5v as the Vout is 4v. So if its 4v which it is, houd have 1.v = - Vin? (Multiply both sides by what ?) Sorry.In your circuit we have this situation:
From KCL we know that:
I2 = I1 (1)
And
I2 = (Voh - Vp)/R2 (2)
I1 = (Vp - Vin)/R1 (3)
Aditional form opamp "theory" we know that "switching" occurred when Vp = Vn and Vn = Voh/2 (4)
Therefore we and up with this:
(Voh - Voh/2)/R2 = (Voh/2 - Vin)/R1 (5)
So, we can plug the numbers and solve it for Vin (V_LTP):
2.5V/12kΩ = (2.5V - Vin)/18kΩ ---> multiply both sides by 18kΩ
2.5V/12kΩ *18kΩ = (2.5V - Vin)
3.75V = 2.5V - Vin ---> subtract 2.5V
3.75V - 2.5V = -Vin
1.25 = -Vin ----> multiply both sides by -1
Vin = -1.25V
But this is just elementary school math.
Multiply or divide both sides by -1.1.v = - Vin? (Multiply both sides by what ?) Sorry.
for the negative saturation is this correct following the KLC as aboveMultiply or divide both sides by -1.
Sorry for coming late with a doubt.
We take it from VpSorry for coming late with a doubt.
What about the output taken from the non-inverting input? Is that justified / explained?
Because the original circuit was a negative impedance converter (NIC) "converted" to Schmitt trigger (when positive feedback wins the fight).What about the output taken from the non-inverting input? Is that justified / explained?
We take it from Vp
Thanks. Have to learn about that NIC to understand this.Because the original circuit was a negative impedance converter (NIC) "converted" to Schmitt trigger (when positive feedback wins the fight).
And of course, you can take the output signal from the opamp output as we usually do.
Look here:Thanks. Have to learn about that NIC to understand this.
