Positive Feedback Schmitt Trigger Calculation. Help :(
Faheem25
Joined Oct 24, 2019
35
Look:
(5V - 2.5V)/12kΩ = (2.5V - Vin)/18kΩ
(2.5 - Vin)/18 = 2.5/12
(2.5 - Vin) = (2.5*18)/12
2.5 - Vin = 3.75
Vin = 2.5 - 3.75 = -1.25V
I see, someone told me to do this. Is that right. Two different steps. Maybe you could explain what this would be for, circuit type etc.
@Jony130 MOD.E
Jony130
Joined Feb 17, 2009
5,598
Well, almost right. But because your circuit is not a standard Schmitt trigger.
In this case, you need to use a "general rule":
To be able to find the Upper/Lower threshold Voltage you need to know that the opamp output voltage for positive saturation (Vcc) and for the negative one (Vee), +5V and -5 for an ideal opamp.
Then you need to find the Vin value for which the voltage at non-inverting is exactly equal to the voltage at the non-inverting input.
And you must remember that the non-inverting input voltage in your circuit will also changes together with the opamp output voltage.
Faheem25
Joined Oct 24, 2019
35
You wouldn't mind calculating that for me please. I got 2V
Faheem25
Joined Oct 24, 2019
35
But I already did just that in post #13
Okay just trying to simplify it a bit more and ill tell you my steps.
I= Vin -Va/ R1 = Va = Vout/ R2
Va = 0 need this value for the switch to occur.
Vin/R1 = Vout/R2
R1 = 18k R2 = 12k
Vout = +/-5V
Vin = (-)18k/12k (+/-2.5V) = -3.75V
So far good? What does the 3.75 indicate, the switch to occur? or is that 2.5..
You're saying its now 2.5 - 3.75 = 1.25V. what does that 1.25 indicate. Sorry, been long time since ive done this
ericgibbs
Joined Jan 29, 2010
21,547
hi 25,
This sim shows the Threshold points at +/-1V ,with a Vout of +/-4V
The Hysteresis range is +/-1V [ 2V total ]
With an actual 741, the Vout range is approx +/-Vsupply -1V, so with a +/-5V supply , Vout range is +/-4V
jony chose the Vout+/-5V as for an ideal amplifier, so the threshold voltages where +/-1.25V
Do you follow OK.?
E
Faheem25
Joined Oct 24, 2019
35
hi 25,
Do you follow OK.?
E
Oh god. So Vout is 4v.
Could you calculate it all for me please:(
Faheem25
Joined Oct 24, 2019
35
hi,
All you have to do is fit 4v instead of 5v in jonys posts #13 and #20.
Post your attempt.
E
This is what i did yesterday, so is this correct but maybe i need to change it to 4V rather than 5V. Vout is actually 5V.
Is that correct but with 4V rather than 5Vout? I believe its 5V Vout
Jony130
Joined Feb 17, 2009
5,598
Or you can use your "method" (superposition principle) and solve this:
LTP:
\[ V_{LTP} \frac{R_2}{R_1+R_2} + V_{OH} \frac{R_1}{R_1+R_2} =\frac{V_{OH}}{2} \]
Where
V_OH is a Positive output voltage (for an ideal Opamp V_OH = VCC)
Faheem25
Joined Oct 24, 2019
35
Do you see the voltage divider connected to the inverting input? What is the voltage than at the inverting input?
yes it would be 2V ?
I don't know why i am struggling with the method, i would honestly appreciate if one could present the full calculation including the formula. would be a massive help
