Hi. Not sure if this is the correct topic to post this under, but I am using a hall sensor to measure a sine wave on a linear motor. I have several of these motors and several sensors that I need to make coordinate with one another to produce one sine signal. I have a sine wave, but no way to line up the waves perfectly from sensor to sensor. I am thinking that I need a second positioning signal in order to line up the other sine signals together as the rotor slides through, but I am not sure if there is an easier way to do this. I basically need to feed this signal into a variable frequency drive as if it was an encoder input, and our drive can take a sine input directly. I just need to get one wave out of all the sensors tied together along the line of linear motors. I know I probably didn't explain this very well so please ask if you need more information!
Thank You,
Joe
Thank You,
Joe
