MaxHeadRoom
- Joined Jul 18, 2013
- 30,788
Mine has 14 x 1.2v Li_ion cells.
Yes I have had a DeWalt DCD996 apart recently. This is a modern Lithium tool with brushless motor, quite a different animal from the anemic NiCD tools of the relatively recent past. I can PM pics if you're curious but I don't want to discuss further here because TS already stated he has a small motor and it would be a distraction to the thread, but the motor was pretty impressive and I wouldn't be surprised if it drew 60A. The drill is rated 820 watts (Unit Watts Out*). 820W / 20V = 41A.Have you taken one of the cordless/battery powered drills apart? The one (a Craftsman 18V ni/cd don't know the model number) that I took apart the motor is now where near what a corded one is. The cordless one has a small hobby motor size in it. High RPM motor with much gearing to bring the speed down and the torque up, to match a corded drill.
Hello there,I have a 18VDC portable drill which needs a new Li battery, but as is often, this battery is obsolete. Is there any way I can get this to work i.e. by sourcing a new battery or converting to 120 VAC?
NiCad and NiMH are 1.2V chemistries, but LiIon is 3.7V.Mine has 14 x 1.2v Li_ion cells.
Those 775 motors seem to be all over the place with regard to power output. On the page you linked, 3 of them have stall current >100A, with the highest 12V motor being 143A and the highest 24V motor being 68A. I assume these higher power variants are what go into cordless drills; probably the 24V one for a 20V tool. So maybe my contrived calculation for cordless brushed tools based on amp draw of corded brushed tools wasn't completely out to lunch?@strantor I dug up the motor from the drill, it's a very common 775 PM brushed motor. The version with bushings not ball bearings. https://www.nbleisonmotor.com/RS-775-Dc-Micro-Motor-pd6675924.html
I have a newer brushless drill and they are much more powerful.
That's pretty clever. TS could do this, if nobody on ebay is making an adapter for the obscure Canadian Tire brand tool he has. Or if it is cost prohibitive.@strantor
I used part of one of the drill batteries to make an adapter for a more modern battery to use in the impact driver that came with the drill. The left is the original battery, right is the adapter to use a Worx string trimmer battery.
When I bought the string trimmer, it came with a very slow charger. They make faster chargers so I bought one. From time to time I needed the impact driver but didn't want to buy new expensive batteries for it. Looking at the craftsman battery and the Worx charger they were almost the same size at the parting line. so this is what happened. The Worx batteies are pretty cheap on Ebay so now I have 3 of them so there is always at least one charged and ready to go for whichever tool needs it.That's pretty clever. TS could do this, if nobody on ebay is making an adapter for the obscure Canadian Tire brand tool he has. Or if it is cost prohibitive.
Well, they made both, it seems. So who knows?I opened the battery compartment and they are NI-Cad, doesn't jive with the tool description!
Advertising dept error maybe???![]()
