Portable drill conversion
beatsal
Joined Jan 21, 2018
425
I have a 18VDC portable drill which needs a new Li battery, but as is often, this battery is obsolete. Is there any way I can get this to work i.e. by sourcing a new battery or converting to 120 VAC?
Dodgydave
Joined Jun 22, 2012
11,395
You can get a replacement battery if that model is available from the internet, or you can use a PSU and make it run on mains supply, ideally what current rating it needs will help to source the PSU.
strantor
Joined Oct 3, 2010
6,875
If you look on ebay there are several people selling 3D printed adapters to use different brand batteries on power tools (ex: use Makita batteries with Dewalt tool, or Dewalt batteries with Milwaukee tool, etc). Maybe you will have some luck finding something for your obsolete tool.
Jon Chandler
Joined Jun 12, 2008
1,636
I had a 12 volt drill with a defunct battery. I attached a 12 volt cigarette light plug to it – very handy for little projects in the car or RV.
Laptop chargers usually put out 19.5 volts. One of these should be ok to run the drill from line power.
28,124
My experience adapting a battery tool to external power instead is that the connection wires and the external supply must provide several amps of current. The 19 volt computer supply might have adequate capacity, maybe.
strantor
Joined Oct 3, 2010
6,875
agreed. Current requirements of cordless tools (and current capacity of cordless tool batteries) are not typically published by the manufacturers. Their tools work with their batteries and that's all you need to know (per them). However if you look at their corded tool cousins, you can infer how many amps might be required.
EX: Dewalt corded drill, 1/2" chuck: 120V/10A
120V * 10A = 1,200W
If this were a 20V cordless variant such as this:
1,200W / 20V = 60A
I doubt any laptop chargers will supply 60A
You might think that the corded tool offers more power than the cordless one, and/or that the cordless one has a more efficient motor to require less current. That is probably valid to an extent, but I own both these tools and can vouch for the corded one being not perceptibly much more powerful than the cordless one, and that they're both brushed and get hot in the hand after prolonged continuous use.
Laptop charger might work for smaller cordless tools (electric screwdriver, high speed rotary tool, flashlight, etc.) though.
Ya’akov
Joined Jan 27, 2019
10,285
What are the make and model of the drill?
MaxHeadRoom
Joined Jul 18, 2013
30,778
What I have done in the past is open up the clip-on battery compartment and replace the Li_Ion batteries with off the shelf types,
28,124
There might be an honest local battery store someplace that was willing to sell individual replacement cells. Unfortunately there are also incompetent stores that claim to repair battery packs and do a poor job of that. Anybody wanting to know the detail can PM me, I am not naming names here.
beatsal
Joined Jan 21, 2018
425
If anyone knows where I can get these cells kindly let me know. I think they are sub-C. I am in Toronto but have contacts in Detroit ann arbor.
strantor
Joined Oct 3, 2010
6,875
You would need to open it up and see what P/N is on the cells. Whatever they are, you can buy them online. Maybe you could get them locally too, but for sure they are online.
MaxHeadRoom
Joined Jul 18, 2013
30,778
If you wanted to convert to AC supply you could build an external supply using a 120v - 12v transformer, with bridge rectifier and a large electrolytic cap.
Gut the battery compartment and use it for cable entry.
shortbus
Joined Sep 30, 2009
10,049
120V * 10A = 1,200W
1,200W / 20V = 60A
Have you taken one of the cordless/battery powered drills apart? The one (a Craftsman 18V ni/cd don't know the model number) that I took apart the motor is now where near what a corded one is. The cordless one has a small hobby motor size in it. High RPM motor with much gearing to bring the speed down and the torque up, to match a corded drill.
