PNP to NPN advice pls
YorkshireDave
Joined Jun 12, 2016
59
20200419_174917.jpg20200419_174829.jpgThe bottom image is a circuit I'm trying to make. However, I have loads of 2n3055s so wish to change the power transistor. Im aware that it can be done as its just a single transistor and that all other polarities need to be changed.
Im hoping that my modifed cct is now correct and so would really appreciate someone much brighter than me checking it pls.
Many thanks in advance
34,958
It is not going to work. The transistor is pointing the wrong way.
Why did you turn all the voltages around?
That makes the circuit confusing. Go back to the original drawing and replace the transistor.
38,584
You can use an NPN by connecting the emitter to ground with the collector to the load, and the load connected to V+.
That's called a low-side switch.
The main difference is that the transistor is now ON when the 555 output is high instead of low.
dl324
Joined Mar 30, 2015
18,410
Just replace the transistor and drive the LEDs low side instead of high side.
Why did you redraw a schematic that was mostly readable upside down? Better schematic symbols have the inputs primarily on the left and outputs on the right to facilitate the preferred left-to-right and top-to-bottom flow.
