Hello guys, In a PNP current mirror does somebody know why the Noise Voltage at my Load decreases with the increase of the emmiter resistors value?
Yes, but in this case the noise voltage at my load decreases, i assume that it might be the Emmiter Resistor at the transistor if it´s bigger, there is less mismatch between both emmiters resistance and therefore the noise gain decreases, or myabe it coud be something related to less dissipated power by the transistor (smaller Vce) and ir produces less noise to the load. But I dont knowA resistor Johnson (thermal) RMS noise is proportional to the square-root of its resistance.
yes but with resistors in the emmiters (with the same value)Yes, but in this case the noise voltage at my load decreases, i assume that it might be the Emmiter Resistor at the transistor if it´s bigger, there is less mismatch between both emmiters resistance and therefore the noise gain decreases, or myabe it coud be something related to less dissipated power by the transistor (smaller Vce) and ir produces less noise to the load. But I dont know
yes but with resistores at both emmitersBy current mirror I take it you mean this configuration where R2 is the load? If that is the case I am not sure what you mean by an emitter resistor:
exactly
what are you measuring the noise with a scope? Sorry for all the questions, just trying to understand the test setup.exactly
it´s amplified many many times, and then it goes to a signal analyserwhat are you measuring the noise with a scope? Sorry for all the questions, just trying to understand the test setup.
My theory would be it is current noise. If you increase both emitter resistors the programmed current goes down and the current noise measured in microvolts per volt across the load goes down, but this is a squared term here because not only does the current go down through the load but so does the voltage, thus it goes down due to both less current and less voltage across the load. Thermal noise is not a function of voltage or current so it would in theory remain the same.it´s amplified many many times, and then it goes to a signal analyser
My that I assume you are referring to shot noise?My theory would be it is current noise.
Possibly, I got it from this link among others:My that I assume you are referring to shot noise?
I am starting to think they are not the same. From this quote:My that I assume you are referring to shot noise?
the paper you send me had some interesting things, thanks.1/f noise is different. Current (Schottky) noise and Voltage (Johnson) noise are independent of frequency.
1/f noise is much more difficult to quantify mathematically. Each device will have its "1/f noise corner" specified on the datasheet, which is the frequency below which 1/f noise dominates. Above that frequency noise voltage/current is flat, below that frequency it rises at 6dB/octave as frequency falls.
Have you read Doug Self's "Small Signal Audio design"? If not I can scan the relevant section for you.
Whatever you do, don't type "Doug Self Small Signal Audio pdf" into Google, because that might find you an illegal copy.
by Jeff Child
