Please suggest common JFET's for general use
Fran3
Joined Mar 28, 2019
51
I looked in my parts supply and discovered while I have many BJT transistors ... I only have one JFET ... a 2N5484 N-Channel JFET.
Amazon has some good deals on BJT transistor kits but I see nothing on JFET's except a package of 10 J310 FET's for $7.
I started looking because I wanted to add a voltage controlled variable resistance to a circuit.
Regardless of this particular application ...
Please suggest some common JFET's I should have in my parts inventory for various DIY projects...
And any good sources or deals for JFET Kit's or whatever.
Thanks for any help.
38,829
JFETs are seldom used anymore, and they have a very non-linear resistance change vs. Vgs, with the resistance only being linear for a small Vds voltage deviation.
Fran3
Joined Mar 28, 2019
51
Thanks MrChips.
crutschow, if not JFETS to create a voltage controlled resistance is the current method to use MOSFETS?
Ian0
Joined Aug 7, 2020
13,281
J108 to J113 for N-channel, J175 to J177 for P-channel
If you want one for low-noise audio then try 2SK3557, and you can get noise figures below 1dB.
