Please Read - Trouble with Powering Stepper Motors
Aleksandar Boskovic
Joined Jan 17, 2019
How do I increase the current output of a power supply using a transistor? I am using a 12v .5 amp power supply for 5 stepper motors that call for 2 amps each in parallel. The transistors I have access to are S8050 D 331 and PN2222A 6E.
Moderators note : reduced font size, large fonts are like shouting.
bertus
Joined Apr 5, 2008
23,014
You can not increase the output current of a powersupply by just adding transistors.
You will also need a much bigger transformer.
Bertus
MaxHeadRoom
Joined Jul 18, 2013
30,860
If you use PWM etc for driving the stepper, the DC power supply V will need to be higher than the required plate voltage of the motor, this is in order for the drive to maintain the exact required current throughout the rpm range.
Max.
