Please need help for sine wave inverter.
Muzamil Farid
Joined Nov 24, 2015
4
I am working on sine wave inverter and i really need serious help,It will be heavily appreciated, I am controlling H-bridge(High side P channel,Low side N-channel) via SPWM signals and 50HZ Square Pulses.The first leg controlled by SPWM and other leg controlled by 50HZ square waves, I am confused about the functioning of P-channel Mosfets, How are they conducting?.What is the criteria of conduction? The source of high side p mosfets is 12V dc to be converted to 220V,50Hz sine wave,My confusion is that output distorted Sine wave will have a peak of 12V?. After implementing on proteus I am getting 0v between two outputs of H-bridge.
Muzamil Farid
Joined Nov 24, 2015
4
So am i confused, your using square waves making a sine wave, lets have a circuit diagram please....
Thanks for the reply, Actually i surveyed on the internet and found the designs using 50HZ Sqaure waves on the right leg of bridge, I am obtaining Sine waves from SPWM control signals,The only explanation i could find of using 50HZ Sqaure wave was that it controls polarity and PWM signal controls amplitude of output wave,I
Dodgydave
Joined Jun 22, 2012
11,307
Is L1 a transformer?, if so the secondary winding is not drawn, that will step up the voltage to 220V ac, or whatever its designed to give out, dont see the point of C1 .
