Please Help with precission oscillator
Danilito
Joined Apr 15, 2017
I have to solve this circuit from linear technologies. I need the function of frequency depending on temperature.
Does anyone know how to start solving the circuit? Thanks in advance.Esquema sensor_3.JPG
MrAl
Joined Jun 17, 2014
13,784
Did you check the data sheet for the LM134? That is temperature sensitive so you can start there.
Jony130
Joined Feb 17, 2009
5,599
Interesting circuit, Lm134 is a current source but this current will depend on the temperature. And this 10nF capacitor together with an opamp for the integrator circuit. And those two complementary BJT's form a thyristor (SCR) structure to quickly discharge the capacitor. But how to determine the initial charging current I do not know. For sure we need to know the voltage across this adjustment potentiometers. The LM329 is a 6.9V Zener so the current through 6.2kΩ is around 1mA. But what port of this current will flow into 2k ADJ resistor I do not know yet.
