please help to sort out this questions
micropad
Joined Dec 24, 2011
109
A high voltage system is made up of the following Generate G1 60MVA capacity with 0.1 per unit reactance Generated 2 80MVA capacity with 0.15 unit reactance. each generator is connected to 33kV busbar through a cable of impedance ( 1 +j2). A 30MVA , 33kV transformer with 0.05 per unit reactance is connected to the busbar. using the base of 120MVA , calculate the 1. p. u impedance of each generator, the cable and the transformer
[This post was moved into the Homework Help forum from elsewhere in accordance with AAC rules concerning coursework related questions —Moderator]
38,952
No I am waiting getting ready for exam on Monday
That qualifies as homework here.
So, if you studying for an exam, then you should have been taught how to solve such a problem.
Please show your best attempt at a solution, as this is a Homework Help, not a Homework Do forum.
micropad
Joined Dec 24, 2011
109
what I need to verify that.... should I need to find out the total impedance of the systems with respect to new MVA as the given values are per unit values
