Please help to resolve the circuit and need the details
RANJIHELLO
Joined Jun 20, 2017
11
Base Control switches from 0 to 5V
Transistor Data: Beta =100, Vce (Sat) = 0.3V, Vbe(Sat) = 1.2V (Max); IC(Max) = 1 A
Relay Data: coil 12V, impedance 300 ohm
Calculate:
1. R1?
2. Power dissipation when transistor ON
3. Find base voltage, base current, collector voltage, collector current
4. What is the purpose of D1?
Alec_t
Joined Sep 17, 2013
15,156
Is this school/college Homework/project?
D1 may be in the wrong place. A diode should be in parallel with the relay coil, to catch inductive spikes when the relay switches off.
AnalogKid
Joined Aug 1, 2013
12,268
DECELL - as this obviously is a homework question, the process is to let the TS show his work and justifications first, then comment and advise without just giving away the answers.
<MOD NOTE> The offending post has been deleted </MOD NOTE>
AND, there is nothing wrong with the placement of D1 because we don't know the context of the question. If the base voltage is 5 Vacrms, D1 is required to protect the transistor.
ak
