PLEASE HELP ME!! running a 3.6V Led
ben hughes
Joined Sep 6, 2016
15
Hi all I'm running a High power LED but having lots of problems. the specs are:-
Power Dissipation: 10W
Chip: Bridgelux
Life: 50,000h
Forward Voltage: 2.0-3.6V
Forward Current: 700mA
I'm powering this with 4 x AAA's
I only have 2 questions.
1) how long will the LED last before it burns out if i just carry on running it straight of the 6V (4 x AAA's) this doesn't have to be exact just a rough idea.
2) what resistor do i need to run this and still get the max light out of the LED
ericgibbs
Joined Jan 29, 2010
21,458
hi Ben,
I don't think God is a member of AAC, maybe I could help.?
With a 6V voltage source and say 3Vfwd for your LED, you must drop 3V at 700mA.
That's 3v/0.7A=4R at 2.1Watt, so use at least a 5Watt resistor.
E
ben hughes
Joined Sep 6, 2016
15
hi Ben,
E
ah i see i originally got a 2w 390mA resitor and the LED was really dim to almost out in brightness.
so i need to have a larger watt to allow more power through and that should work :)
can i ask if i didn't use any resistor i get a major bright light but if it's meant to last about 50,000hrs i'm thinking it would last around 2- 5000 hrs.
you don't have to be exact but what duration of life would you possibly give it?
ben hughes
Joined Sep 6, 2016
15
AAA batteries cannot run a 10W LED for long
I'm basically making a lightsaber for my son and the LED is great and i don't need it to last for days to be hounst if i can get it to last for about 6 hrs that should be enough. i hope 4 x AAA's would do this? i'm more than happy to test it though :)
any thoughts?
ben hughes
Joined Sep 6, 2016
15
hi Ben,
E
getting a 5w resistor is easy but what do about the Ma?
Alec_t
Joined Sep 17, 2013
15,121
If the AAAs are good quality and fresh you might get a fraction of a second :(.
I'm rather concerned that you're using such a high power LED for a child's toy. Looking directly at it could cause permanent eye damage.
ben hughes
Joined Sep 6, 2016
15
your not able to look directly at the led it's in the base of the blade and the blade has a film which lights up when it's turned on. i've tested it a few times and it's had no problem with 10+ mins before i took the cables of the power points
joeyd999
Joined Jun 6, 2011
6,330
For reference:
http://data.energizer.com/PDFs/E91.pdf
Expect about 1,000mAh capacity at 700mA (from 1.5V to 0.8V per cell). Probably about an hour of run time.
But, as the batteries discharge, the LED will quickly dim long before the 0.8V/cell is reached.
A switcher will give constant brightness through the whole battery life, but expect less than an hour.
ben hughes
Joined Sep 6, 2016
15
right i see thank you.
the power supplie is going to go through a rocker switch i should have mentioned that sorry.
i was going to use a 5 watt resistor on this to try to make sure the led wont burn out and last's longer.
i did a test a while ago with a 3.7v 1200mah battery and the led lasted 3.5hrs so i'm hoping for better this time if i can just get it to work correctly
