Attached is a table showing what the voltages should be and what I measured as well as a schematic. Some voltages are high, some are low, some by a lot, some only a little. They are highlighted. There were high and low voltages before the repair but now some are worse and there are a few more. There are no burnt components.
The radio had been running fairly well lately despite the odd voltages. A few days ago a small encapsulated PC board had a cap blow out. I rebuilt the circuit on a separate PC board. This circuit, PC-2, is highlighted in orange and is in the upper right of the schematic. Most voltages are similar to what they were before this happened. Pin voltages that did not come back to normal are highlighted in light blue. All components in rebuilt circuit check out good yet some voltages in blue on the attached table are far from what they were before the repair.
I noticed noise about the time I noticed the damaged PC-2. The noise is still present after replacing the PC-2 circuit but I can't find a faulty component nor can I even narrow it down to a specific part of the circuit. The noise is definitely coming from the circuit and is not coming from the power supply or through the antenna. It is present as soon as sound can be heard from the speaker. It does not change as the unit warms up. The noise is a crackling, rumbling sound occurring at random, usually a few times a minute. It is not constant, it comes in short bursts. It reminds me of the sound lightning makes on an AM radio. I'm guessing it may be another bad cap but everything I can see looks good. I hope it's not in one of the other PC boards such as PC-4 in the audio circuit.
The noise is not as loud if a dummy antenna is attached. I don't know if there is noise being transmitted.
I can pick up circuit noise with an inductive probe but I can't tell where it comes from. Cap C-7 coming from pin 8 of tube V-1 has always had more circuit hiss than any other component yet it checks out good and replacements are no different. C-8, C-9, C-14 have slightly less hiss.
I've tapped and wiggled each tube and each pin and everything else but there are no bad connections and the tubes appear to be good.
I only have a DMM to test with and I'm not familiar with how the operation of one tube could affect what's measured on another tube. If anyone out there has any ideas I'd appreciate it if you can give me some idea where to look.
Thanks
Thanks
