Please explain pin of tl494
circuit29
Joined May 20, 2017
26
Hello I want to generate pwm from chip can you explain how chip work how to build circuit?
For single pwm not push pull
Alec_t
Joined Sep 17, 2013
15,124
From an Application Note :-
"One function of the error amplifier is to monitor the output voltage and provide sufficient gain so that millivolts of error at its input result in a control signal of sufficient amplitude to provide 100% modulation control. The error amplifiers also can be used to monitor the output current and provide current limiting to the load."
What 15Ω resistor?
JohnInTX
Joined Jun 26, 2012
4,787
circuit29
Joined May 20, 2017
26
sorry 150ohm 2watt
What 15Ω resistor?
