Please could someone define slew rate?
The higher the index, the more details of the signal component reduction ability, otherwise you will lose some resolving power.
Op-amp conversion rate is defined as, operational conditions, the closed loop will be a large signal (including step signal) input to the input end of the op-amp, measured from the output of the op-amp increased rate of the output of the op-amp.
