Please can anyone find for me the Gain?
student111111
Joined Jul 26, 2016
3
Greetings
I do understand that u might be suspicious and worried about your pc there is plenty of trojans around so for that how do you recommend me to upload the figure you would like it on Dropbox or via email or whatsapp Image or any other method kindly note that is is an urgent issue and I would like to find the gain of this circuit
I attached the graph here if this is not enough or not a trustworhty issue let me know!
Thank you in advance
Ali
Bordodynov
Joined May 20, 2015
3,429
Apparently you do not understand.
Gain = Vout / Vin = V (out) / 1V = x.
The question you have put wrong. Maximum transmission coefficients on the pseudo-resonance is 1 = 0db (at a frequency of 159Hz =1/(10k * 0.1u) / 2Pi. On the other frequencies ratio is less than 1. Carefully watch my pictures. I showed what is (analytically) transfer coefficient. I used complex number.
hp1729
Joined Nov 23, 2015
2,304
Certainly something for me to learn here. Math aside .. the output is connected to the non-inverting input. Shouldn't that follow the inverting input for a no gain condition? Frequency characteristics of the op amp not considered in my thoughts, of course.
Given your formula, if we double the values of R3 and R4 we get a gain of -2. ??? It seems the output of the op amp would follow your math but the output of the circuit is not the output of the op amp.
(edited to add ...)
Or will the inverting input be at virtual ground and the output following that. Not no gain. no output???
Or a current output like a Howland Current Pump?
