PLC diagram to logic equation and truth table
Matherios
Joined Feb 25, 2018
74
Hello I'm having a really hard time making the logic equation and the truth table of this Plc diagram.
So far i have went till this part of the equation.
  • Q0.1=(Q0.1*(I0.1 * ^Q0.1))+I0.1=>
  • Q0.1=(Q0.1*I0.1)+I0.1
  • (^)=Inverse
I don't know if im correct with the equation but it's the first time i have the output of a circuit as an input aswell of the same equation.
MaxHeadRoom
Joined Jul 18, 2013
30,881
I am not that familiar with programming ladder logic in Boolean, most PLC's can be programmed in an alternative Step style language that resembles Boolean in a way, and an output function used in a logic function would have the same address as the output.
Max.
Matherios
Joined Feb 25, 2018
74
yes here is the functional block diagram of the same circuit.But still i have the same problem,i can't figure out how the logic equation will be when as input in the equation is the output aswell.
MaxHeadRoom
Joined Jul 18, 2013
30,881
Most likely treated exactly the same way as it is in the ladder format, IOW, although being shown as a condition inside the rung, the address is the same. and treated the same as an input would be.
Max.
Matherios
Joined Feb 25, 2018
74
What is IOW?
Also the Q0.1 switch (not the relay) depends on the condition of the Q0.1 (relay), for example when the relay is energized then the switch Q0.1 is closed.So how can i take Q0.1 switch as an input?
MaxHeadRoom
Joined Jul 18, 2013
30,881
  • (^)=Inverse
On review it looks like you have it right, What is your reference material you are using?
Any PLC make in particular?
Max.
MaxHeadRoom
Joined Jul 18, 2013
30,881
I guess the bottom line is that an output that is used in a rung as a logic function (e.g. OR/NOT) is characterized like any input function and the (output) label designation remains the same.
Max.
