I have the Samsung Plasma and as the title mentioned, it has no sound nor image. Based on what I have found, it should power module's problem, but I could not find any blown fuse or cap. Any suggestion on what I should do?
Look which caps look bulged on the PSU module and replace them. If you don´t see any then you need an ESR meter, or if you have a shop close by change them all.
before going too deeply,disconnect the leads to the y sus and z sus panels and see if yr set powers up......chances are you may have a failed sustain panel in which case replacement panel and driver may cure your set......
