Pioneer A/V Receiver Repair
RandyRiver87
Joined Aug 16, 2019
13
I don’t think they are 2W while I stared blankly in my electronics store at the hundreds of resistors they had I looked at the 2W resistors and they are noticeably bigger. I will go with 1W as you suggested.
Good news is I was able to reassemble the unit just now and power it up and confirm all other inputs are working except for the problematic one. There is *some* sound coming out of the “bad” one which resembles a “blown speaker”.
The actual board that needs to be worked on is easily removable without taking the whole unit apart again.
I will order the parts and post an update on the outcome.
I am very grateful for all the help you guys have provided. You guys are great!
Thankyou again.
RandyRiver87
Joined Aug 16, 2019
13
Also, one more question.
Under the transistors there is thermal paste, should I add new thermal paste to the new transistors or will what is there be sufficient to reuse?
Ylli
Joined Nov 13, 2015
1,092
If you have it, I would recommend you redo the thermal compound. Also, if these was a mica insulator, be sure that gets reinstalled (Some of these TO-3P cased transistors are fully insulated and do not require the mica).
RandyRiver87
Joined Aug 16, 2019
13
I received the parts in 5 business days, installed and I’m back in business all for $12 including shipping.
There was no mica insulator, replaced both transistors and both resistors. Everything good now.
Thankyou very much everyone.
Resolved.
