Pioneer AV receiver VSX-324 repair
Wilder1626
Joined Apr 17, 2022
6
Hi all.
This is my first posting, hope I'm at the right place.
I have a Pioneer Amplifier that does not want to power on.
Actually, it does a click, but does not Power on. If I keep pressing on the Power button for 2 seconds (2 to 3 relay clicks), then it powers on. Could that be a relay problem?
I've tested it with a multimeter, and I do have a continuity. So i don't know if this could be a intermittent problem.
What would you say could be the problem?
Thank you for your help.
sagor
Joined Mar 10, 2019
1,056
Post the model of the amplifier, someone may have a solution. Otherwise, guessing in the dark does not work well.
It may be whatever is feeding the relay, the relay itself, of something else....
Wilder1626
Joined Apr 17, 2022
6
Thank you. I do hear a click, but no lights, no front panel lights up. The only time it really turns on is when it clicks 3 times (press for two seconds). After that, it works without any problem.
35,321
When you say "it works without any problem" are you say that the receiver is fully operational?
Wilder1626
Joined Apr 17, 2022
6
Correct. It is fully operational. In fact, I used it all day yesterday without any problem, after turning it on this way.
Connected to it: 1 TV, 6 surround speakers: subwoofer, front left and right, rear left and right and center, 1 Blu-ray, 1 TV terminal
Mgergo1998
Joined Aug 23, 2023
Hi, i have the same problem, did you manage to solve this problem? Or if not is you reciever still working fine like this? Thank you if you answer!
Mod Tag: @Wilder1626
bassbindevil
Joined Jan 23, 2014
924
Some of these receivers have a self-test that will disable the speaker relays if a fault is detected. The service manual should explain how to reset that fault and/or display an error code. Common faults seem to be bad power amp output devices, and defective voltage regulators.
