Piezoelectric Transducer with Arduino
SAM7121
Joined May 22, 2017
I want to drive piezoelectric transducer with resonant frequency 110khz and input voltage 70 volts ac with arduino. I generated a square wave of same frequency with arduino than converted it into ac voltage using RC filter than for the step up I used transformer small getting amplitude of 67 volts peak to peak. When I connect piezo to transformer the amplitude falls to 2 volts. The piezo is not working.
Is there any other way to drive this piezo?
Thanks in Adavance
SAM7121
Joined May 22, 2017
1.SPECFICATION
1 DIMENSIONS
As per the drawing No. KS-W20-113KHZ
2 ELECTRICAL SPECIFICATION
2.1 Resonant Frequency (fr)
fr = 113kHz±5kHz
2.2 Resonant Resistance (Ro)
Ro = max. 150Ω
2.3 Capacitance (Cp)
Cp =2000pF±20%
TEST PROCEDURE
1 TEST ATMOSPHERE
23±3ºC 40 ~ 70%RH.
2 Fr AND Ro :
The TH-2818 Impedance Analyzer.
3 Cp
LCR meter at 1kHz,1Vrms
INPUT FOR TRANSDUCER
MAXIMUM INPUT
Voltage: 70 Vp-p
POWER
Max Input Power 2.0W.
(Normal use 1.5W)
